My Tech Sheet show’s the following Elements with their resistance range:
Bake Element 25-30 Ohms
Inner Broil Element 45-55 Ohms
Outer Broil Element 45-55 Ohms
Convection Ring Element 28-35 Ohms
I’ve used an Ohm Meter to test each and found:
Bake Element 28 Ohms
Inner Broil Element 33.1 Ohms
Outter Broil Element 56.5 Ohms
Convection Ring Element 1.2 Ohms (honestly it jumps all over from .7 to 2.5 and I know this element is bad)
My questions:
It appears my Inner Broil Element is weak and my Outter is somewhat high. Do I need to replace them or are the OK like this? If I need to replace them can someone point me to the correct part for my oven and some steps to replacing them?
I clearly need the convection ring element and I’ve found this part but do you know if I replace it from inside the oven or do I need to pull the oven out and replace it from the back?
Usually elements go open (infinite resistance) so it is probably OK.
Basically it is a straight wire coated in a ceramic so they cannot partially short out to give a lower resistance.
I would check it’s resistance to the mounting plate.
Use a high meter scale and it should be infinite ohms.
