Oven Element Blew, replaced, now won't stop heating
Okay, I have a roughly 7 year old Whirlpool Super Capacity 465 Electric range/oven. Model number rf3020xkq.
A couple of days ago I was cleaning the oven out (it is manual clean) and had a momentary lapse of genius :). I thought I had unplugged it and unscrewed the bake element and proceeded to pull it out. Well, it wasn’t unplugged and the part of the element just beyond the male end of it (i.e. the part that holds the male connector to the actual round element itself) touched the frame of the oven and well, yes, you guessed it I got quite a large white/blue sparks and flames show. I know, idiot I am, but that is besides the point. So, after I unplugged it, I took a closer look and it appeared that the only thing that happened was the the piece that I was referring to above had burned in half - essentially the male end of the element was now in the female wire end. I was able to get it out easily and carefully examined the wires and connection points and to my surprise, they all looked perfectly fine - there was no charring, burning, or melting at all. I took the cover for the wires off the back of the oven and checked that out - again all looked fine.
I did NOT check the wiring in the top part of the unit (which I suppose I should).
I purchased another element, put it in last night and turned it on - it worked and heated fine; however, I only turned it on 150 and only left it on long enough to be sure it was heating and then turned it off.
I come home this evening and my wife showed me two plates of biscuits that were burned badly..This is not usual for her bc she knows how to cook. She said that the oven never stopped heating. We do not have a preheat option, but the oven usually turns off after it gets to the temp of the manual dial is set to. Apparently it didn’t. The knobs were also quite warm to the touch, which is unusual.
Another thing I noticed was that the biscuits were really burned on the top and not the bottom at all, which makes me think that the broiler was on. My wife is certain the broiler was not on.
What else could have happened here and how can I test it? I do have a multimeter and know how to use it, just not sure what to check on the oven. Thanks!
Mike
I took the cover off and eyeballed and checked all the wires and connections. It all looks near brand new to be honest. So I turned the oven on - selected bake on the element control and put it on 250 to test to see if it would turn off. I opened it up and took a look and immediately noticed that the broiler and the bake element are turning on, which is obviously not supposed to happen. What would cause this to happen? THanks!
Mike
I just had the same thing happen to me today! I was being smart and removing the bottom element from the oven to clean it for the wife! However, I noticed that it was plugged into the oven like the top burners are! So, I started to push the element back into its housing when it sparked and then a loud pop! Scared me to pieces!
I was looking at the manual online for our Whirlpool Super Capacity 465 and there is a Oven Temperature Sensor located underneath the cook top of the cover! This is supposed to make sure that the oven is heating up to the right temperature and stop there!
Follow the link to a PDF page for your oven located here…http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf.
The electric range componants location page is on pg 25 of 32. You might also want to check the Oven Thermal Fuse as well.
I am sure since this happened back in November, you have already gotten a new stove or had it repaired. Hope that this helps you or anyone else that did the same things as we have done! LOL!!!
