Oven door will not latch
Son in law says latch came completely loose and he put pack. Door will not latch so oven will not heat as it should. You can hold latch in closed position and the oven will work. Do I need to replace the whole latch assembly and does it come with solenoids etc or do I need to replace only the solenoids etc and not the latch. Thanks
I reccomend you replace the complete assembly, I would if it were me.
I’m sure you’ll find something bent or broken in the switches or linkage, with the kit you’ll be set and ready.
(see attached/click on part number)
AP6009413
:cool: :cool: :cool:
