Oven Door Trim Replacement Kit
I was replacing the springs in my oven door. While putting the door back together, I broke a small tab off the bottom of the side trim. While checking online for a replacement, I found out that this piece was no longer available. Instead, I was referred to a new trim kit the manufacturer had made available. Now, I have the door trim replacement kit, but can’t get the glass front to fit with the side trim pieces in place.
Has anyone else had the same problem?
HELP!!!
What is the part number for the trim you used?
