After a loud sound from the side of the upper oven door, it appears that the right side hinge spring has either broken or become detached causing reduced tension on the closing of the door. I have identified a replacement spring but wanted to know how much trouble it is to repair this type of problem (i.e. - how do I disassemble to replace part?) Thanks
