Oven door replacement
the glass recently broke on my oven door, i purchased replacement parts and have the door all fixed and ready to go back on. Except i guess I was supposed to save the door removal pins that i received when we purchased the oven. I don’t know what they look like or what they are supposed to do now that the door is off. Looking on line I see a lot of information about putting a nail in an alignment hole to keep hinge up but I can’t see where i would do this.
Please Help
Hi.
Use the pair of channel locks or heavy duty pliers to open the hinge, only then you’ll be able to see the hole.
Be careful - it’s a strong spring.
Simon.
I performed the repair by sleeving the spring with a brass tube exactly as described in the technical manual here:
Garage Door Repair Fontana
It works perfectly!
Casette di Legno
