Oven door removal
Just received glass for oven door on my Kenmore model 66592012100. I need to remove door and cannot find instructions for removing door on this type of hinge
Info on how to remove it should be in the opeerators manual.
If you do not have the manual you should be able to download it from a site called ManageMyLife.
You will have to join the site to get the manual.
Below is what I could copy from the manual. The manual it self has some pictures.
For normal range use, it is not suggested to remove the oven
door. However, if necessary, follow these instructions. The oven
door is heavy.
Before Removing:
  1. Use a putty knife or screwdriver and insert it at the bottom
    corner of the door stop clip.
  2. Pry door stop clip free and remove from front frame hinge
    slot. Take care not to scratch finish.
  3. Repeat procedure for other door stop clip.
To Remove:
  1. Open the oven door. Insert door removal pins, included with
    your range, into both hinge hangers. Do not remove the pins
    while the door is removed from the range.
  2. Carefully close the door until it rests against the door removal
    pins.
  3. Grasp the door on the sides with your fingers on the front of
    the door and your thumbs on the inside surface.
  4. Pull door straight up, then toward you. Hinge hangers will
    slide out of front frame hinge slot. Do not remove door
    removal pins until the door is replaced on the range.
    The storage drawer can be removed. Before removing, make su
To Replace:
  1. Grasp the door on the sides with your fingers on the front of
    the door and your thumbs on its inside surface.
  2. Hold oven door so that the top edge of each hinge hanger is
    horizontal. Inserf hinge hangers into the front frame hinge
    slots.
  3. Tilt top of door toward range. Slide hinge hangers down onto
    front frame support pins. Make sure the hinge hangers are
    fully seated and engaged on the supporf pins.
  4. Insert the door stop clip with the angular surface at the top of
    the frame hinge slot, then push in the bottom of the clip until
    flanges are flush with the front frame.
  5. Open the door completely and remove the door removal pins.
    Save door removal pins for future use.
  6. Close the door.
Below is the hinge, if you click on the picture a new page will open. It has a Q&A section that may also help.
AP6011640
