Feb 23, 2012
I cannot remove the front door of a white-Westinghouse Four A convection oven Model WFS81TW-1. I would appreciate your help in removing this door or finding a manual for it that describes how to do it.
Thanks.
Mohinder
Feb 23, 2012
Thanks.
Mohinder
Open the oven door completely.
Can you see 2 screws located on the inside of the oven door liner near the door hinge?
If you can, remove these screws. Insert the 2 screws into the door hinge holes located on the side of the hinge arms, one into each hinge. Close the oven door until the door stops. Do not force the door to close any further. Grasp oven door firmly on both sides and slide the door up and off hinges at the same angle.
[quote=Gene;673862]Open the oven door completely.
Gene.[/quote]
[FONT=Arial]Hello Gene,[/FONT]
[FONT=Arial] [/FONT]
[FONT=Arial]Thanks for your suggestion. I am somewhat confused about the screws location.[/FONT]
[FONT=Arial]Do you mean the two screws (TOTAL OF 4 SCREWS LOCATED ON THE RANGE AND NOT THE DOOR) on the top and bottom of the each hinge where they enter the range frame? Or do you mean the two screws ON THE RANGE DOOR on outside of the metal seal about six inches from the hinge?[/FONT]
[FONT=Arial]Mohinder[/FONT]
I meant the screws located on the inner door panel (liner). One on each side.
