Oven door pulled off
Went to lift up on my oven to slip a rug under it & the door came off large lower oven. Cannot get it back on the oven. Any hints?
Below is the operators manual.
It has info on removal and re-install of the door.
You have to get the hinges into the locked position and then install it.
http://www.maytag.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%20W10430934.pdf
