Oven door help?
How does one take off the oven door? It will not lift off at all so I’m not sure what to do next. Otherwise, I can’t get to the lower element screws to remove them and change out the element (burned out) Any ideas? :confused:
Below is a link to an operators manual for a JBP35BHCT.
Yours is probably the same
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80494-1.PDF
