Oven Door Handle Repair
I am looking to get some guidance on how to repair a loose door handle on my Jenn-Air Duel Fuel Range. I called Jenn Air but they tell me they do not have any schematics on how to do this.
Also the knobs need to be taken off and put back in the right spot. Any help would be appreciated.
Here’s how the door breaks down. Door parts for Maytag JDS8860BDP - AppliancePartsPros.com
It isn’t over-complicated; but you DO need to pay very close attention to how it comes apart, in order to get it back together correctly.
Open the door to the first stop. You may see a catch on the hinge (both sides) that can be moved to release the door from the oven body. Place the door face down on a well-padded surface and disassemble it from the inside out, until you expose the handle plate screws (#s 5 and 18 in the drawing). That’s your target.
