Oven Door Glass Replacement Question
Gravity had it’s way with one of the metal kitchen chairs and shattered the oven door’s glass. :eek:
I noticed as I cleaned up the pieces that the original glass panel was held in place at the sides and on the bottom by some heavy-duty, white double stick tape or adhesive.
I ordered the replacement piece of glass for it and it arrived yesterday. Instead of replacement double stick tape, there are three pieces of adhesive aluminum foil - two rectangles, approx. 2.5" x 5", and one strip, the length of the glass (approx 20") and about 1.5" wide. :confused:
I checked with Frigidaire’s parts catalog and it calls out the foil and not the tape, so I think I have the right parts. :slight_smile: How should these pieces of foil be applied? :confused:
Unfortunately this is beyond my expertise. May be somebody else on the forum can help you better.
