I need to know how to replace the inside oven door glass on my Dacor oven. I’ve got the part but am not sure how to remove the old glass and replace it. Any suggestions ? Thanks in advance for any info you give.
Attached you find the Oven door break down diagram.
Oven door.pdf (67.2 KB)
Gene - thanx for the oven door diagram. I’ll give it a go.
Keep me updated, please.
Gene,
Thanx again for the detailed expanded diagram. It sure helped. I got the old part out ok and went to install the new glass unit only to find it defective. One of the mounting tabs on the frame of it was missing. I just removed the frame of the old one and used it. Took a bit more time but it all worked out in the end. Oven now works great.
Barry
Happy New year!
Thanks again for your help. Happy New Year to you and yours as well!!
it seems I want the glass assembly
do i need to take off the door from the oven to gain access to the screws to dissassemble? should i replace the outside metal gasket at the same time or can i put it back?
thanks
wkh,
What is the complete model number of the oven? The oven door always has to be removed for any repair.
How do you remove the oven door on the CPS130
