Oven door does not stay closed
I have a Maytag oven model #SVD486006 and when I close the door it springs back open about 1 inch. I have changed the hinges, hinge recepticals and the door seal gasket. (its not the new gasket keeping it open). I can not see anything bent or warped. Any ideas? Thanks
Per the Mayatg Technical bulletin (attached to the reply) the correction is to install the door hinge kit.
Door not closing properly.pdf (15.2 KB)
