I have a self cleaning GE Oven. The outside door is easily cleaned, however the inside of the door(where theres a window inside) needs cleaning and I cant get to it. What do you suggest for the cleaning . The entire door from the outdide looks like there are drips coming down
Thanks in advance for your help
The only way to clean it is to remove the door and take it apart.
