Oven control panel
on my gas range, when oven is on, it will shut off and “door locked” :confused:
message will appear. after pushing various buttons, the stove will occassionally reset and start again, only to go off shortly. This does not happen every time i use the oven, but is happening more frequently. what could be causing this?
[QUOTE=t l schoon;308268]on my gas range, when oven is on, it will shut off and “door locked” :confused:
message will appear. after pushing various buttons, the stove will occassionally reset and start again, only to go off shortly. This does not happen every time i use the oven, but is happening more frequently. what could be causing this?[/QUOTE]
It sounds like you have having problems with the clock control board (ERC). The part # is WB27K10148. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
