the control panel for the oven & clock doesn’t work, no display at all. the oven doesn’t work. all surface element’s do work.
Larry
Parts for Frigidaire FEF366CCE Range - AppliancePartsPros.com
Here is a better copy of your wiring diagram.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255311.pdf
Do the oven light and the surface indicator lights work.
If not then you may have a power problem (no neutral).
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Be careful as 240 volts is lethal !!!
If the lights work then probably the control board (Item 20 in Backguard Parts) is shot. You will also probably need a new overlay (Item 20A), the old one may get messed up trying to remove it.
I would check all the wires going to the control board especially L1 and Neutral.
You cold also check that the board is getting power but this can be a pain to do due to the limited space.
both the surface & oven lights work.
Larry
Thank’s. I understad the procedure, except how(where) do you connect the meter to neutral ?
Larry
If it is wired up 3-wire then any bare metal on the frame is Neutral (ground).
Also the center terminal (white) on the terminal strip is Neutral.
