The lower heating coil is not working, top one (broil) is working. Does this mean that we need a new heating coil or could it be something else? Do you think we can install it ourselves or do we need to hire a professional? Help, it is a few days away from Thanksgiving dinner at our house!!!
Thanks! Lynn
Here your parts
Replacement parts for 59F-5TXW models | AppliancePartsPros.com
I cannot find any tech info on this unit.
It may be just the bake element has burned out,
In any case this is the easiest place to start.
Remove power from the unit.
This is very important as on many units one side of the element is still live even with the element shut off.
remove the screw/s holding the element to the back of the oven.
Gently pull the element forward till the connectors are in the oven.
Undo the wire going to one side of the element,
Measure across the element.
Should be around 20 ohms.
It is not a bad idea to clip something onto the wire so that it does not disappear into the back of the oven.
if the element is OK then it could be the relay board or the control board.
Also I noticed the unit has a couple of hi-limit thermostats, one of these may be blown.
Cannot tell how they are wired in without a wiring diagram.
