I have a frigidaire model # FEFL78CQA oven/range. While baking the other day I heard a loud “pop” sound and noticed that my oven and my display stopped working. My stove top however still works. What can I do or what may need replacing to fix this problem. I have taken the back off and do not notice any burnt wires. Is there something else to look for? Thank you in advance for all your help. It is greatly appreciated.
Here are your parts, includes a wiring diagram.
Parts for Frigidaire FEFL78CQA Range - AppliancePartsPros.com
I am assuming that when you say the stove top works that the indicator lights also work and that the oven light works.
Unplug the unit ans visually inspect the oven elements for signs of damage.
Also run your fingers along them just to be sure that the coating is OK. Often when an element blows it will also blow the control board.
Probably your control board is bad. You may see damage on it but not always.
If not then you may have lost Neutral. The lights and control board run off of half the line (L1 to Neutral)
