Brand: Whirlpool
Model Number: WFE540H0ES0
Main Symptom: not working
What happens & when: oven/burners do not work
Error Code (if any): F9E0
Parts or tests already tried: turned off power
Brand: Whirlpool
If the cooktop burners aren’t working along with the oven that means you have lost your L2 electrical leg either between the terminal block and the components or you’re not getting L2 into the range from the source electrical system of the home.
F9E0 is a miswire code indicating that L2 has been lost.
