I changed the oven and broiler ignitors only to find out no power going to them . the controll panel works when i hit clean timer bake broil it turns on the on signal.the latch works during the clean cycle but no ignition. is there a relay in the controll panel . I am told the controll pad is no longer available
[quote=solutionman;314274]I changed the oven and broiler ignitors only to find out no power going to them . the controll panel works when i hit clean timer bake broil it turns on the on signal.the latch works during the clean cycle but no ignition. is there a relay in the controll panel . I am told the controll pad is no longer available.
I changed the oven and broiler ignitors only to find out no power going to them . the controll panel works when i hit clean timer bake broil it turns on the on signal.the latch works during the clean cycle but no ignition. is there a relay in the controll panel . I am told the controll pad is no longer available.[/quote]
P.S. Repeating the same question four times within 15 minutes does not do anything good for you. Instead such thing decrease your odds of getting a relevant reply dramatically.
