Out of balance problem
Our Kenmore 11027822790 washer seems to have a off balance issue when it spins at times, not the usual clothes to one side thing, I thought these washers had a out of balance warning and or switch to shut it off, if the washer starts shaking too violently. and I have been seeing suggestions about checking springs, what springs would this be, and how many are there? Thanks
[QUOTE]I thought these washers had a out of balance warning and or switch to shut it off, if the washer starts shaking too violently.
[/QUOTE]
Not on this model.
There are four springs on your washer.
I would remove the washer cabinet and check the springs and the skate plate.
Well, something doesn’t work right, it had a off balance load today, and and it was shaking so violently, before we could get it shut off, it broke the lid switch, it is a miracle that is all that happened, this is unacceptable.
