The timer dial on my Maytag only work on the timed Dry Cycle. Vents clear. Clothes dry perfectly on that cycle but no Intellidry/Airfluff or Perminent Press/Intellidry cycle works. Is it the Timer itself since it does partially work. Or could it be a sensor? Please advise.
Does it start the cycle?
[quote=Gene;107519]Does it start the cycle?
Gene.[/quote]
On the regular cylce when I pull up on the knob nothing happens at all. No the cylce doesn’t start. Only when I used the timed dry cycle and that works just fine not slow or anything.
Sounds like the timer has gone bad. If you need the correct part number post the serial number of the dryer.
[quote=Gene;107715]Sounds like the timer has gone bad. If you need the correct part number post the serial number of the dryer.
Gene.[/quote]
That is what I thought. #12716496CA is the serial number. Thank you! Janet:D
Janet,
The timer AP6008005
Here are the breakdown diagrams and Replacement parts for MAYTAG MDE7400AYW | AppliancePartsPros.com
