Roper dryer only drys on low heat. If set to regular dry or more/less dry the dryer spins but doesn’t heat at all
Replacement parts for Roper REX5634KQ1 DRYER | AppliancePartsPros.com
Set the timer to where you have heat.
Unplug the dryer.
Check timer switch 2 connections with a meter, it should be 0 ohms.
Now move the heater to a setting where you do not get heat (re: high heat)
Re-check timer switch 2, it again should be 0 ohms.
If not you need a new timer.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
REX5634.pdf (231.4 KB)
