Brand: LG Model Number: WT7200CV Main Symptom: On normal wash the countdown timer will freeze and the fill cycle and spin cycle start together. Would it be the control board or the water valve or both ? What happens & when: On normal wash the countdown timer will freeze and the fill cycle and spin cycle start together. Would it be the control board or the water valve or both ? It appears the other wash cycles work fine but the normal cycle is the only observed problem.
Error Code (if any): None
Parts or tests already tried: N/A
Photos / video link: N/A
Thanks for the info. I now have an update. The problem now happened on bedding cycle, where on start the sense and fill cycle starts and the water continues when the wash cycle starts. I’m guessing the control board still guilty, or should I get the valve also ?
