I had to trip some circuit breakers yesterday to replace an overhead light, and in looking for the correct circuit, briefly removed power from the microwave. I turned it back on within 5 minutes and found the correct circuit to accomplish my task. The LED clock on the microwave works fine, so it seems to be getting power. I can set the cook time, but the start button does nothing. Is there some kind of reset button somewhere? Any ideas? Thanks.
The model number you posted does not come probably due the age. Post the wiring diagram if you have it. Otherwise itβs hard to say what could be wrong.
