Brand: JennAir Model Number: CVGX24223B Main Symptom: Continues attempting to ignite after flame has been lit. What happens & when: After lighting any of burners, all 4 burners will continue clicking/igniting.
Parts or tests already tried: Attempted to clean and aligned the caps for fitment.
One of the igniter switches are stuck in the closed position. With the power supply cord unplugged from the outlet, and the grates, burners, and top panel removed, the igniter switches can be tested for continuity. With one wire disconnected, each switch should show no continuity when tested in the off position. If one has continuity, it has failed and would need to be replaced. Here is a link to what switch would be used with this model. The link also has a repair video that can be used for reference. WP71003385 Switch/Ignitor (Spark Igniter Switch) | Genuine Whirlpool OEM In Stock
