Older Gibson electric oven gasket issue
Older 1960’s-ish(?) Gibson oven was in my house when I bought it. Oven seal/gasket was deteriorated and ripped. From this site I figured out how to loosen the oven liner enough to pry the broken pieces out. Problem is I can’t find the correct part to fit. I have called this site customer service and the contacted the research team and said they do not make the part anymore. I have also tried to search for the part under model number and can’t fin anything. I just want to know if there is another part that will work for this stove its a plain rubber looking gasket. no clips. I can post a pic if that will help. Thank you ver much.
it looks very similar to this GE WB2X1522 Gasket, Silicone - AppliancePartsPros.com
