[quote=denman;869382]Here are your parts
Parts for GE TFX25PAYAWW Refrigerator - AppliancePartsPros.com
----> Why did you replace the defrost parts?
The Defrost Timer and the Defrost Thermostat were parts that other sites suggested as culprits for my trouble. As it turns out, the defrost timer that I took out has stripped and “burned” gears when opened and inspected. I thought that was surely the problem until it did not fix the problem. Then I replaced the Defrost Thermostat. Still not fixed.
----> The symptom you give does not point to a defrost problem.
Well, that is interesting to read. I hope the parts that I put in were of good quality.
I think the old Timer needed to be replaced.
----> Check the temperature in the freezer. It should be between 0 and 5 degrees F. Could be it is just too cold.
I will have to find a thermometer, but will check that asap.
----> Check the temperature on the middle shelf in the fresh food side it should be about 38 degrees F.
----> Check that the vents between the freezer and fresh food sections are clear on both sides.
If you are referring to the damper passage at the top of the refrigerator, then that area is clear and the damper works.
----> Check that the meat pan control is not letting to much cold air in.
Is this the dial on the center wall that is built in to the hardware for the bottom crisper drawer? If so then it is clear.
[/quote]
A bit of history if it helps -
- The diffuser cracked and had to be removed some time ago. The evaporator fan had been broken a few times and has now been replaced twice. GE does not (as you know, I’m sure) make the diffuser panel any longer for replacement. I am not quite sure what impact this has on the airflow from Freezer to Refrigerator, but I sense that it is different than if the diffuser panel was there.
- I had to leave the evaporator fan without a blade for a few days. I ordered a part online and had to wait for arrival. That meant that the evaporator was turning the spindle, but there was no air moving. This may very well have been when things went south.
- This may be unrelated, but there is a strange vacuum event that happens every time the freezer door is closed. There is a loud gurgling sound from the drain tube. It appears that the tube pulls water from the pan underneath and sprays it back onto the back of the bottom drawer in the freezer. This seemed to be happening with the same timeframe as the above failures.
Thanks again for reading.
