Dryer spins but doesn’t heat… was wondering if there is a common part i could start with. I already tried the fuses. Its an older house so yes there are fuses. Any info would help thanks!
Replacement parts for WHIRLPOOL LER6634DW1 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
As you can see there are a number of parts in the heater circuit.
You could check the heater as visually you can tell if it is blown.
If in auto modes the timer advances then the heating coil and the 240 volts are OK.
If the thermal cut-off is blown there are other parts that should be checked before replacing.
As far as a “common part”, I would say a meter is where to start. It will let you check most parts in the heater circuit with the unit unplugged which is the safest way to do it.
LER4634.pdf (125.0 KB)
