I had a repairmen come look at the unit. Upon inspection, he said there was not a model number on the plate. This is obviously a very old unit. I would say the house was built in the late 40’s or early 50’s and I suspect it was put in with the house.
The plate did contain a serial # (ER 17802) and a CAT# (SU4) It also said volt 115 - 230 on it.
It contains two 8" burners and two 6" burners. The picture is below.
Can you help me determine the model and the possibility to match parts?
Thank you!
