Old Maytag Washing Machine Model: MAV7600AWW
Brand:
Model Number:
Main Symptom:
**What happens & when:**Have an older Maytag Washer Model: MAV7600AWW Just ordered new drain pump and drive belt. Order #17048962Want to make sure the parts ordered are correct and do I need to reuse old attaching plate for new motor or does it come with new plate
For the pump that you got, the mounting plate would need to be switched over. To determine the correct pump, the first 2 digits of the serial number would determine this. If you have a serial number between 10 - 25 you would use the following pump which would have the mounting plate.
https://www.appliancepartspros.com/whirlpool-swtch-slide-wpw10252122-ap6017872.html
If you have a serial number that starts 26 or higher then the one that you ordered is correct.
