The following questions are in regard to a very old (30+ yrs) Modern Maid, combination Cook and Clean (oven, stovetop, dishwasher), Serial Number: 008282-026. I am trying to determine the cause for the oven no longer heating. The clock is set in the “manual” operation mode and the indicator lights come on. The bake element does have a burned area and needs to be replaced, but the broil element, which appears okay, does not heat either. This lack of heating appeared instantly, not gradually. The screw-in fuse inside the panel is okay, at least it is not burned and has continuity. The stovetop burners glow red when on high, so it would appear that the appliance is receiving all 240 volts. Are the bake and broil heating elements wired in series rather than parallel, so that the bake element has to function for the broil element to work also? Or is there something else causing the total lack of heat, such as a defective thermostat? Whirlpool still makes a replacement bake element (#AP4273316), but that particular thermostat is no longer available and I can’t find any listing for an alternate one. Any information will be greatly appreciated.
Remove the wires from the Bake element and check for 240 VAC to the Bake element while the thermostat calls for Bake. If there is no proper voltage then check the wires from the thermostat and, if there is nothing wrong then the thermostat is the culprit. In such case it’s probably time for a new oven.
