Oil is shooting from below the agitator during the spin cycle.
I opened the front panel and there are no visual oil leaks.
Hopefully the fix is a seal replacement?
Any advice is GREATLY appreciated.
Thank you! ![]()
Thank you! ![]()
We looked up the transmission for this model, and there is no seal to replace. However I’m attaching a link to the parts diagram, and a part number for the transmission. This will fix your problem.
34526 transmission assy replacement parts for AMANA AWM593W WASHER-TOP LOADING | AppliancePartsPros.com
Hi Jeff, thanks for the info.
I read somewhere that there is a drive bell and seal kit under the agitator that may be a culprit. Have you experienced fixes with changing out these things?
I don’t think that will fix your problem. When you change those parts, it’s usually for a leaking or bearing issue. You have an oil issue. Now if you change the transmission, it is recommended that you chang the seal to prevent leaks. Here is that part number for you.AP4253766
