Brand:LG Model Number:LDP6810SS Main Symptom:OE Code What happens & when:
Error Code (if any): OE Parts or tests already tried: Cleaned Filter Photos / video link:
Check to make sure that there is nothing caught in the drain pump. This error will be a drain issue. If there is no clogging then check to make sure that there is 120 vac to the pump. If there is then it would be a faulty drain pump.
Thank you. How do I order a drain pump?
If you click the following link, it will take you to a parts page for the drain pump.
https://www.appliancepartspros.com/lg-case-assembly-abq75742505-ap7206236.html
