Dryer Model: 110.8888291
The timer on my Kenmore 90 Series Electric Dryer is not advancing. The dryer is tumbling and heating. I am not sure which timer I need to replace the malfunctioning one.
When I type in my model number online nothing comes up. The model number on the timer and the timer itself appears to be different from timers used on similar models.
Also, I opened it up and tested it with a multimeter. The timer motor is not working and two of the contacts inside of the timer shows signs of arching and melting.
Would you be able to suggest a compatible replacement timer?
https://drive.google.com/drive/folders/1Yk1ZdP8mD_rZ4slKdTq6QBDp32AQEti6?usp=drive_link
