Not sure if this is a DIY fix
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Greetings – My 15 year old GE (models JKP64G0P4B6) wall oven has begun behaving badly. It is taking much longer than usual to preheat and won’t stay at the proper temperature. Iwould like to try my hand at repair if it is something straight forward but, don’t know how to diagnose which part might need to be replaced. [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]If I heat the oven to 350 it will slowly come to temp but not go back on to stay at temp correctly. I can see how the temp changes by turning the oven off then back on. When it turns back on it displays the current temp.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Is this symptom typical of any particular part failing?[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Thanks in advance,[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Suzie[/COLOR][/SIZE][/FONT]
I could not find info on the given model number but the following is a JKP64GP4BG.
Replacement parts for General Electric JKP64GP4BG Electric range | AppliancePartsPros.com
First I would check that both elements work.
Most units either turn on both elements during pre-heat or switch back and forth between the elements.
If one of them does not get hot then odds are it is burned out.
To check it.
Remove power from the unit.
Undo the screw/s holding the element to the back of the oven.
Carefully pull the element into the oven.
Remove the wires from it and check it with a meter.
Should be around 20 ohms.
Sometimes you can actually see where the lement burned out but usually you cannot.
It is a good idea to clip something (clothespin etc.) to the wires so they do not disappear into the back of the unit while you are checking the element.
[COLOR=“Red”]Turning the power off is very important because on most units there is still voltage to one side of the element even when it is turned off.[/COLOR]
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
