Gene There are NO LED’s on the face panel of my ice maker - just on - off - clean buttons - the only LED is the clean light - no blinking. (are the LED’s located any where else) Update: I ran the ice maker today three seperate times lets call it test 1, test2 and test3 Test 1 result: the unit ran fine for aprox 2 1/2 - 3 hrs made ice went through 3 full cycles - after the third cycle the unit shut down. i noticed alot of heat coming from the lower section of the unit where the fan, compresor and condensor is located. during cycle 2 and 3 of ice making the fan ran very slow and at times shutting off and on Test 2 results: same as test 1 ( I let the unit cool down for 1 hr before starting back up) Test 3 results: same as test 1 ( i let the unit cool down for 4 hrs bfore startingback up)
