Not Drying Clothes in One Cycle
Brand: Whirlpool Dryer
Model Number: WGD72HEDW0
Main Symptom: Not Drying Clothes in One Cycle
What happens & when: Clothes are wet at the end of the cycle
Error Code (if any): Nove
Parts or tests already tried: Clothes are hot
Clothes are not dry at the end of the cycle. We purchased the moisture sensor, Part #:
AP6008273 (WP3387223), Qty=1. I installed the part & noticed there were two parts that looked exactly the same. Should I have replaced both? The clothes are still not dry after one cycle. Could there be another problem?
That could be the moisture sensor and it is usually recommended to replace both together, but if it seems to be actually running the cycle and not stopping within just a few minutes of start-up then the sensors are probably fine. The thing that usually helps is placing a level on top of the dryer facing front-to-back and raising the front of the dryer by about 1/4-1/2 bubble above level, make sure the side-to-side stays level. This trends the clothes towards the back of the drum and often prevents the cycle from prematurely ending.
