Not cold enough
Refridgerator seems to be cold enough but freezer is “just cold enough”. We moved it from one house to another and now this is happening. The fridge was not layed down. It was fine before this. There is a “clicking” sound when adjusting the freezer temp (temp at adjustment?). but no click on fridge adjustment knob. Suggestions? Thanks
Check in the back for a bad/jamed condenser fan. If ok and the compressor is not very hot, measure the freezer temperature and post. Also, remove the freezer back panel and check the frost pattern, must be entirely covered with a light frost.
