I’ve had my Kemore dishwasher for about 2 years. Recently the Normal Wash light started blinking about 18 times straight, hesitates momentarily, and continues the blinking cycle again.
I first unplugged the original board & plugged it back in & it worked for a week or so. But, then it started the blinking again. That little trick no longer works.
I replaced the circuit board with a new one. The problem still exists.
I tried another suggestion of toggling HI TEMP WASH/HEATED DRY for 5 minutes. Nothing happened.
I read also the it could be the heating coil or maybe another sensor. I haven’t tried any of these as of yet. I wouldn’t know where to look. Does anyone have any idea what I need to do to get this working again? I am totally stumped on this.
Okay, I’ll give that a try. Another $120 down the drain. :eek: The part was out of stock on the link you provided. As much as I hate ordering through Sears, I went ahead & did. :rolleyes:
I took apart the keypad to see if maybe some water crossed the contacts. It didn’t come apart very neatly, but I was able to wipe some moisture away & get it to start for a moment. It cut back out after awhile. I babysat the thing to get a complete load washed, but this definitely is not the way I want to do my dishes.
Thanks for you assistance, Gene. I’ll post back my results from the new part.
