Normal cycle green light blinking.will not run
Normal cycle green light on control panel blinking. Unit wil not run. Water in bottom did not empty. :confused:
Hi.
Most likely there is a short in the touchpad circuitry.
If you remove the kick panel you will find the tech sheet inside the pocket at the back of it. Go to “Checking keyswitch contacts” and perform the test.
Here are the breakdown diagrams and parts list for the dishwasher
DU1100XTPQ7
Chose the correct color for the control panel or the control board on the diagram # 02.
Good luck. Please keep us posted with the results.
Thank you,
Simon.
