[FONT=Times New Roman][SIZE=3][COLOR=#000000]Accidently, I left a refrigerator door not totally closed overnight. The door was enough to turn off the light and let the refrigerator run.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I noticed in the morning and closed the door of the refrigerator which was running. Since then, it ran nonstop. Freezer OK, but refrig kept at 40 F and not below. I turned it off and let defrost for 24 hrs. I noticed there is a lot of ice on the pipe. I turned it on. Now, it still runs nonstop but refrig goes around 10 F (normal should be 20 – 35). Temp adjuster sets high or low does not make difference.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I believe the deforest system is OK because I found ice on the water collect area.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Most likely, it points to the problem with thermostat. do I need replace the controller as well? Please advise.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Thank you in advance. [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]model: GSS25JFMC WW GE brand[/COLOR][/SIZE][/FONT]
HI.
Unplug the fridge, open the doors and let it defrost for another 24 hrs.
If after that the same problem will occur - replace the
damper assembly AP3186598
Here are the breakdown diagrams and Replacement parts for General Electric GSS25JFMCWW Refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
may i just replace the sensor ?
i think i can measure the changes of resistance of the sensor by freeze or warm up. supposedly, warm up → smaller resistance, cold down → higher resistance, or vice versa ?
why this part goes out of order?
thank you
[quote=Simon / APP Team;751008]HI.
Simon.[/quote]
Hi.
You may try to replace the sensor only, but you’ll be better off replacing the assembly.
Simon.
the part you provided is different from mine.
i have checked the part on my refrigerator. it looks different - connected on the ceiling of the refrigerator, and a seperate sensor goes into the ceiling of the refrig. also, i could not disintall the damper from the ceiling wire.
any advice.
[quote=Simon / APP Team;751102]Hi.
Simon.[/quote]
after i exposed the sensor, and check all the connectors, it works now. i will observe for a while before i put all covers on.
thank you guys.
You are welcome.
Simon.
