When dryer is on it squeaks…any suggestions how to check or oil or change belt…? Any suggestions are greatly appreciated
Pull front panel and check for worn glides. If bad replace with Pn AP2042543
If ok check the drum rear bearing, might be worn out.Replace with Pn AP2042531
