Ice dispenser ok water not working. water ok up to valve solenoids ok. removed front trim, looking for some kind of micro switch found pc board. i stopped. what should i be looking for or check. thank you
[quote=tishie;666324]Ice dispenser ok water not working. water ok up to valve solenoids ok. removed front trim, looking for some kind of micro switch found pc board. i stopped. what should i be looking for or check. thank you [/quote]i have ice. can i swap the solenoids to see if maybe thats my eprobleum
Hi.
Perform the test described in the attached file. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSH25JFRFCC Refrigerator | AppliancePartsPros.com
Water is not dispensing.pdf (258.2 KB)
