No water
I have no power to the valve. I checkerd the float swich, ok, also no power toit either. Removed the console checked all the harnesses, tried moveing wires between the door frame. I also put my meter in the inlet valve turning the timer knob no power all I have is motor, I don,t even think I heard the drain solonoid.
thank you for your help
                                      Dave:confused:
                       Icouldn't find a wiring diagram
Hi Dave,
Most likely the problem is a bad push button switch on the Left side of the console.
Here are the breakdown diagrams and Replacement parts for GE HDA3220Z07BB | AppliancePartsPros.com
There are two switches , pots and pans and normal cycle, can I jump out either of these switches just to be sure.
Thank you
dave
That kit includes both switches. As soon as you open the control panel you will see them burned. You do not need any other troubleshooting.
