We are not getting water into the dishwasher but I have water at supply line. What do you suggest to try? Do we need to order a water valve??
Here is your parts
Replacement parts for GE GSD3230ZZ2WW | AppliancePartsPros.com
Check that the float is activating the overfill switch. It may be stuck in the up position or for some other reason not activating the switch Item 307 in “Body parts” section
If you do not have a meter, you may want to get one.
Check that the overfill switch’s contacts are actually closed.
You can then check the valve coil for continuity, if open it is shot.
Can also check that it is getting 120 volts to activate it when the unit should be filling.
One other thing is that the water valve has a screen filter on it’s input side.
It may be clogged up.
Shut off the water supply.
Check it, if clogged up clean it. Do not remove it from the valve, it is there to prevent crud from getting into the valve, holding it open and causing a flood.
Have a shallow pan and towel handy to catch the water from the line.
[COLOR=Green]I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
There is a good STICKY at the start of this forum about it’s use.[/COLOR]
