No water coming out of washer
As of yesterday my washing machine NO water comes out of my washing machine! if the lid is closed you can hear it come on and if the dial is moved to spin that works as well. Checked the hoses and everything is attached properly but i am getting no hot or cold water AT ALL.
please please help! i am a mother of 7 so going more than a day or two without doing laundry is a full blown nightmare.
frigidaire top loading washing machine
fws6600fs0
about two years old and never had any problems so far
Hi
You need to determine if power is getting to the water valves. You will need a meter and the service manual, or even better, a friend with a meter. Can’t help you there, but here is a service manual that should cover your unit.
http://frigidaireservicetips.com/pdfs/489_5.pdf
If power is getting to the valves when the machine is in fill, the valve assembly is broken and will need to be replaced.
If not, and I imagine that is the case, your water temp switch or timer is the issue. I suspect it will turn out to be the temp switch, which you will also have to test using the wiring diagram in the manual.
