Changed my water filter yesterday. I installed the filter and after about 30 seconds I removed the new filter to check something. When I removed the filter there was a large pop of air. I re installed the filter and the fridge dispensed water fine. Today, no water. Never a problem before today. Is there something basic I can do to get this operational? Thanks for assistance, Charlie.
Hmmn?
I Had The Same Problem Problem On Mine. No Water To The Dispenser And No Water To The Ice Maker.
Check The Refrigerator Temp Dial. Some How Mine Got Set To A Coolder Temp Setting And The Water Supply Coil Line Inside The Rerigerator Compartment Froze. I Reset To A Warmer Setting And Waited A Day.
Thanks for taking time to feedback. I think I just got some air in the line and needed to bleed it for a bit. All is well. Thanks again
