No Spray
Dishwasher stopped spraying water. It will fill with water but does not spray. The motor sounds okay.:confused:
I tried many different washing combinations and even tried a dishwashing cleaning agent with super hot water. We have been washing dishes by hand for a month. :frowning:
I had a really bad experience with a dishwasher repair man once, and do not want to pay $$$ to fix it when I could buy a new one for a little more $. I would like to do it myself, but not sure want to do.
Hi.
Here are the breakdown diagram and Motor-Pump Mechanism parts for GE GLD4560N10SS - AppliancePartsPros.com
You need to check:
-if the fine filter #451 and coarse filter #502 are clean.
-if the ball is still inside the tube in the sump #505 and it’s moving free up/down.
Moving up/down the ball is switching cycles from wash to drain redirecting the water flow.
Post the results.
Simon.
